Activity › Forums › Panasonic Cameras › Print to video: NO TIMECODE? SD footage HVX200A
  • Print to video: NO TIMECODE? SD footage HVX200A
    Posted by Zack Hill on January 24, 2010 at 7:47 pm
    Hello, my lack of knowledge of the HVX200a has me very confused…
    Shot footage to P2 in 480i mode, 30p.
    Imported to FCP (version 6.06) via Log and Transfer
    Output to tape (print to video) via firewire to HVX, audio and video show up and record to tape, but no timecode?
    FCP was an easy set up, using DVCPRO 50 ntsc as a compressor
    Capture settings were firewire basic…
    After I recorded to tape (without timecode) I tried to re-ingest with no luck. Tried non-controllable device but could not get FCP to capture more than a few seconds of media.
    Because this needs to get out tonight via FEDEX, I changed settings in FCP and outputted to my Sony deck in SD. Worked fine, just confused on how I would do this if I did not have my trusty deck. And I assume that the network that will be using the footage would want the same compressor that I shot the footage with? (DVCPRO 50)
    Thanks, I googled the hell out of this and found a similar post on DVUSER.com but with no answer…
    Zack Hill
    FCP 6.06
    G5
    HVX200A
    Sony V1U
    Shane Ross replied 16 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    January 24, 2010 at 11:00 pm
    The HVX200 shoots and records DV to tape. DVCPRO 50 will not work. Surprised you actually got video to the camera with those settings.
    Shane
  • Zack Hill
    January 24, 2010 at 11:13 pm
    Ahhh!
    Wrong codec
    so should I output with DV and then print video to the HVX? Will that enable timecode? Or should I be happy with the footage outputted to my Sony deck?
    I’m sitting with my sleeping 2 yr old so I can’t sneak up to the office to experiment
    any advice will be greatly appreciated Shane!
  • Shane Ross
    January 24, 2010 at 11:37 pm
    [zack hill] “should I output with DV and then print video to the HVX? Will that enable timecode? “
    Check it and see. I haven’t output DV to that camera, I always use decks.
    [zack hill] “Or should I be happy with the footage outputted to my Sony deck? “
    If you have a deck, ALWAYS use the deck. Lessens the wear and tear on the camera. Always output to a deck…always capture from a deck.
    [zack hill] “I’m sitting with my sleeping 2 yr old so I can’t sneak up to the office to experiment “
    Oh…then just use the deck. It will need a DV signal too.
    Shane
  • Zack Hill
    January 25, 2010 at 12:58 am
    Thanks Shane
    I was ( and am ) a bit confused on the difference between panasonic DV and Sony. I was thinking that if it was shot on the HVX then it should be outputted to the HVX.
    I’m gonna send the mini DV as is
    thanks again!
    Zack Hill
    http://www.zeechproductions.com
  • Michael Sacci
    January 25, 2010 at 1:40 am
    MiniDV is MiniDV (DV), doesn’t matter if Pan, Sony or JVC.
  • Steve Eisen
    January 25, 2010 at 4:53 am
    Check out page 17:
    https://www.rainbow.gr/markets/pdfs/Video/FCP_Workflow_HVX200.pdf
    I have used print to video on my HPX-170. In DV mode, I do not get timecode. In HD, I get timecode but no audio.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Shane Ross
    January 25, 2010 at 4:54 am
    That’s a little different, as the 170 doesn’t have a tape drive, and he is printing to tape.
    Shane
