Activity Forums Apple Final Cut Pro Legacy print to video FCP 5.0
  • print to video FCP 5.0
    Posted by Steve Foulkrod on November 15, 2010 at 6:06 pm
    Hi guys,
    I’m having an issue in FCP 5.0. For some reason its not letting me print to video. Backstory: I cut 2 sequences with HDV/SD footage, then exported each to a full QT movie with these settings:(NTSC DV 48hz 720×480) thus downconverting the HDV footage. So, this gave me files that were essentially SD, right? So, I burned those sequences into iDVD viewed them on a 4:3 TV & delivered to my client. All good. Now, I want a tape copy for my own archives & cannot seem to get it work. I’ve done this countless times in the past with no issues. Everything appears to be normal, the cam starts recording but nothing records(tried 2 diff cams Canon GL2, & ZR200). I get no image on the cam lcd screen as its recording. My mac sees the cam & I can external monitor through it if I want, but it wont record the sequence??? Btw, I even tried importing the files into FCEHD 3.01 & the same thing happens.
    Steve
    Steve Foulkrod replied 15 years, 10 months ago 2 Members · 3 Replies
