Activity › Forums › Apple Final Cut Pro Legacy › Print to Video / Edit to Tape – HEEEEELP!!
  • Print to Video / Edit to Tape – HEEEEELP!!
    Posted by James Hargreaves on February 1, 2007 at 11:17 pm
    Got a MAJOR glitch going on here.
    Trying to master off a 1.67 PB to a DSR-45. Need timecode accuracy so need to edit to tape.
    When playing from the timeline the video goes through to the 45 no problems but try to Edit to Tape or Print to video – nothing.
    Tried everything I can think of all evening and now it’s nearly midnight.
    I know the 45 works because I did the same thing at the weekend from a quad which I don’t have right now. Need to have this done by the morning or I am toast.
    Can someone rescue me from this nightmare!
    Thanks.
    James Hargreaves
    Duane Needs help replied 19 years, 6 months ago 2 Members · 2 Replies
  • James Hargreaves
    February 1, 2007 at 11:36 pm
    OK – Think I’ve found it. “EASY SETUP” wasn’t set to DV-PAL. Was set to CUSTOM SETTINGS for some strange reason.
    Oh well – another hard lesson learned!
    Good night!
  • Duane Needs help
    March 27, 2007 at 4:38 pm
    Wow, having the same problem in NTSC, couldn’t figure it out, read your post. Fixed!
    Why on earth was easy set up suddenly switched to custom? I must’ve been fiddeling.
