Activity Forums Apple Final Cut Pro Legacy print to video
  • Posted by Ann Lukacs on November 5, 2006 at 11:23 pm
    I’m trying to print a finished project to a DVCAM tape via a Sony DSR-11. The total timeline is approx. 20 minutes and it keeps crashing at about 16 minutes. Any ideas?
    Thanks.
    Ann Lukacs replied 19 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    November 5, 2006 at 11:37 pm
    System details?
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Ann Lukacs
    November 5, 2006 at 11:51 pm
    OS X ver 10.4.8
    Dual 2.3 GHz power PC G5
    2G DDR SDRAM
    Machine Name: Power Mac G5
    Machine Model: PowerMac7,3
    CPU Type: PowerPC G5 (3.0)
    Number Of CPUs: 2
    CPU Speed: 2.3 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 2 GB
    Bus Speed: 1.15 GHz
    Boot ROM Version: 5.2.4f1
  • Walter Biscardi
    November 5, 2006 at 11:57 pm
    No external or secondary media drive? You’re running your media off your System Drive?
    There’s your problem.
  • Arnie Schlissel
    November 6, 2006 at 12:13 am
    [Apple Annie] “it keeps crashing at about 16 minutes. Any ideas?”
    A rule of thumb: if you keep having the same error in the same place, you’ve got a problem in that place. Check all of your audio, graphics & video at around the 16 minute mark. Odds are that something is corrupt or needs to be re-rendered there.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Ann Lukacs
    November 6, 2006 at 12:17 am
    I actually have two external hard drives on the computer. Forgot to mention those.
    Here is where I think I messed up. The media is saved in a folder in the capture scratch on an external hard drive. The sequence and the PTVTmpfiles are being saved in a folder under Render File on the Media HD on the system.
    What do I do?
  • Walter Biscardi
    November 6, 2006 at 12:25 am
    [Apple Annie]
    Here is where I think I messed up. The media is saved in a folder in the capture scratch on an external hard drive. The sequence and the PTVTmpfiles are being saved in a folder under Render File on the Media HD on the system.”
    You never want to split your folders, Simply set the External drive as your Capture Scratch and be sure to also have Render Files also set that same drive.
    Simply reset your Media drives so Render is set to the external drive. Trash your Renders and re-render the project.
  • Don Walker
    November 6, 2006 at 1:59 am
    I had the same problem a couple of years ago, the computer was trying to put my firewire drive asleep. Go to your system prefences and check in the Energy Saver section, make sure you don’t have the computer going to sleep for a good long time, and uncheck the “put hard disks to sleep if possible” box
    John 3:16
  • Ann Lukacs
    November 7, 2006 at 1:45 am
    That did it! Thanks.
