Activity › Forums › Apple Final Cut Pro Legacy › print to video
  • Posted by Saya Hillman on April 22, 2007 at 1:01 pm
    Hello, pretty novice question –
    I am trying to export a sequence to a miniDV tape, using Print to Video. There doesn’t seem to be any communication between my miniDV deck and computer though — I press record on the deck when prompted by FCP and it just records a blank screen. I don’t see the images from my computer on the deck screen at all.
    I’m assuming it’s just a wrong mode I’m in, but can’t figure out what to switch? Thanks, April
    Steven Lambion replied 19 years, 5 months ago 3 Members · 4 Replies
  • David Battistella
    April 22, 2007 at 5:57 pm
    Check the following.
    Is there an enormous amount of black in front of your sequence?
    have you told FCP to go through the Abrs and tone and slate process and set paramteres that have affected teh output?
    Not many details in your post so this is all a hunch. I normally would not respond to a post like this because there is not enough background.
    We are not mind readers.
    David
    Peace and Love 🙂
  • Saya Hillman
    April 22, 2007 at 6:18 pm
    Ouch, testy. Relax and enjoy spring David!
    I figured it out through another forum, thanks anyway. (Easy Setup > DV NTSC)
  • David Battistella
    April 22, 2007 at 9:43 pm
    Dentista,
    Everyone is here to help. It’s hard to do when there is some ambiguity. I wrote this article a while back to help people how to best use the creative cow.
    David
    https://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=200&page=https://www.creativecow.net/articles/battistella_david/good_grazing/index.html
    Peace and Love 🙂
  • Steven Lambion
    April 23, 2007 at 3:34 am
    Try going to Menubar -> View -> Refresh A/V devices.
    If it takes a 2 seconds for it to finish than it probably found something.
    After you might want to go to Menubar -> View ->External Video -> All Frames
    if you can’t click it(Disabled), then FCP can’t find the Deck.
    Also make sure that there isn’t multiple decks or cameras plugged in(the Quicktime library can handle multiple Inputs through a Array, but FCP doesn’t seem to have this feature).
    Video Specialist
    Apple Developer
    Owner of GranitWorks
