Activity Forums Apple Final Cut Pro Legacy print to tape with HDV URGENT
  • print to tape with HDV URGENT
    Posted by Braden Wheeler on September 2, 2008 at 1:43 pm
    Hi all, I’m trying to get an HDV sequence to print to a tape and FCP5 won’t recognize the deck for this. It sees it in my OS, as well as for log and capture. It also has no problem outputting when I set it for DV. This is very frustrating. Is there a setting that I’m missing? I use an easy setup for HDV1080i60 and I’m double checking that the video preview is set for HDV and it’s just not seeing the deck. Thanks for your help.
    Braden
    Jerry Alto replied 17 years, 8 months ago 2 Members · 1 Reply
  • Jerry Alto
    September 2, 2008 at 4:30 pm
    Braden- Knowing your deck model would be helpful. I presume you digitized your HDV directly from this same deck. I would focus on your decks settings… make sure ilink downconvert is set to ‘OFF’. Sometimes I’ve had to quit out of FCP and restart with the deck on.
    HTH,
    Jerry
    G5 Dual 3GB Ram
    FCP Studio 6.02
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
    GV-HD700
