Print to Tape – Image Drop Outs
Hello there!
I am trying to print to tape an HDV video but it keeps failing. It fails on two occasions:
– when I have a countdown animation (each number last for one frame one frame and it goes on faster and faster)
– at the final roll credits (I have used the built in roll credits from Final Cut)
What happens is that the image goes black or gets stuck on the tape for a while and then resumes normally. Sometimes the roll credits roll fine, sometimes not. But the animation never outputs well.
However, when I play the movie from the FCP timeline project it never drops out;
After exporting it as a quicktime movie to make a DVD it never drops out also. The file runs well in the quicktime player as well and even inside FCP if import it there;
The DVD also runs smoothly with the same file.
At first, I thought it was my camera (a Sony FX1) that could not record it well. Then, I went to a studio and the same happened with a very good HDV deck
Unfortunately, in the place where I live, not many studios are Apple based, so now I have to either sort this out and print the tape or go to a PC based studio (running Premiere) with a file so that they try print it to tape themselves.
Therefore, I have 2 questions
1. How can I prevent the recording from getting stuck?
2. If I cannot sort the problem out, what kind of export shall I do in order to keep quality and allow the PC based studio to read it?
Technical details:Software: Final Cut Pro 5.1.4
Computer: Apple Book 2.16 Ghz Intel Core Duo
2 GB 667 MHz DDR2 SDRAMVideo
Format: HD Pal 1440×1080In a couple of days I will have the new Mac book pro and FCP’s last version. Hope it helps.
Thank you so much in advance for any help that may come since this movie is for a film festival and the deadline for deliver has already past.
