Activity › Forums › Apple Final Cut Pro Legacy › print to tape audio and markers
  • print to tape audio and markers
    Posted by George Bonilla on September 14, 2007 at 2:30 pm
    Hi guys, I am trying to print to tape. I have done three of four with only a couple of problems (dropped RT). But this one has me stumpped. It happened on one of the other tapes and I just went in and turned up the audio and re-rendered and it was OK. I have lines and words dropping out. Just a line here or a yell there. The audio is on two tracks mixed together. I have tried re-rendering but it keeps dropping the same lines. On playback of the timeline it is fine. It is taking the audio a long time to render. Also, I have double markers for some reason. I clear all the markers then add in and out and there is another set added to the time line between. I use select in to out and it does bypass these other two. But everytime I clear them all when I add the new ones in these two come back in different spot?
    George Bonilla replied 19 years ago 1 Member · 0 Replies
  • 0 Replies
