Activity › Forums › Apple Final Cut Pro Legacy › print to tape
  • Posted by Alexandre Brandt on April 11, 2011 at 6:20 pm
    Hello all,
    I’ve got Apple Pro Rez videos in 23.97, 29.97 and one PAL 25fps that I’d like to print to MiniDV tapes for archival.
    Should I convert them all to DV 720×480 29.97 for the NTSC ones and in DV PAL 720×576 for the PAL one and then print to tape ? Is there a higher quality format I can use and still print to MiniDV tapes ? is HDV a good option ?
    Thanks for reading !
    Alexandre
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Alexandre Brandt replied 15 years, 5 months ago 4 Members · 4 Replies
  • Zane Barker
    April 11, 2011 at 6:38 pm
    [Alexandre Brandt] “I’ve got Apple Pro Rez videos in 23.97, 29.97 and one PAL 25fps that I’d like to print to MiniDV tapes for archival.”
    [Alexandre Brandt] “Should I convert them all to DV 720×480 29.97 for the NTSC ones and in DV PAL 720×576 for the PAL one and then print to tape”
    If you do you will take a hit on the quality.
    In the last few years, I’ve become a bigger fan of digital archives. Hard drives are cheep.
    **Hindsight is always 1080p**
  • Chris Tompkins
    April 11, 2011 at 9:43 pm
    Ah man, Mini-DV for archival??? That is a horrible way to go.
    Make a Digital Master and put it on a couple hard drives.
    Chris Tompkins
    Video Atlanta LLC
  • Paul Jay
    April 11, 2011 at 9:56 pm
    Just dont!!
  • Alexandre Brandt
    April 11, 2011 at 11:02 pm
    Well I have Full Quality masters in a hard drive + a back up drive but I was thinking of a MiniDV in case.
    -> FILMMAKING !
