Activity Forums Apple Final Cut Pro Legacy Print to Tape
  • Posted by Sam Pope on April 10, 2010 at 12:34 am
    Using the Panasonic HVX200, I did a commercial shoot in 1060 60i. It needs to be delivered on a mini DV tape. I’m using a Sony A1U as a deck and I need to print to tape.
    Can someone tell me how to do this? What do my audio/video settings need to be?
    Mary Bastidas replied 16 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Rob Grauert
    April 10, 2010 at 2:17 am
    I would create a new Sequence in your browser with DV/NTSC settings. If you want it letterboxed, make it 720X480. If you want it anamorphic, simply check the anamorphic box in the sequence settings menu.
    Nest your HD sequence in the SD sequence by dragging it from your browser and dropping it into your SD timeline. It should fill your scale own into your canvas perfectly.
    Then File > Print to Tape
    OR
    I suppose your could use Compressor to downconvert to DV/NTSC. Then bring that new file into a new project and do a File > Print to Tape.
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
  • Sam Pope
    April 10, 2010 at 7:00 am
    Sorry – I didn’t explain myself well. I need to keep the footage in 1080i60, I just need to put it on a mini DV tape using a Sony A1U. Can I put DVCPRO HD 1080i 60 footage on a mini DV tape using a HDV camera? What do my audio/video settings need to be?
  • Rob Grauert
    April 10, 2010 at 12:02 pm
    I would bring your DVCPro HD sequence into Compressor and drop the HDV1080i60 setting on it, then export.
    Being the new file back into a new sequence into FCP. When you drop it into the new sequence, FCP will ask you if you want to sequence to match your source video’s settings…. obviously in this case, Yes.
    You should be able to export to tape then.
  • Kevin Monahan
    April 10, 2010 at 4:57 pm
    You can’t cross convert to DV on the fly unless you have an outboard video card or Io box. Makes sense, right?
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Sam Pope
    April 10, 2010 at 7:58 pm
    I did what Rob suggested, compressed the video to HDV 1080i60, using compressor and when I go to Print to Video, it gives me the error message: “The sequence is not compatible with HDV print to video”
    The sequence is HDV 1080i60, which FCP automatically set to what I dropped the compressed file onto the timeline.
  • Kevin Monahan
    April 10, 2010 at 10:21 pm
    Sounds like a few tests are in order.
    Can you try compressing a small portion of the seq. to different format, say, an anamorphic format? 1440 x 1080?
    Kevin Monahan
  • Mary Bastidas
    April 11, 2010 at 12:09 am
    Greetings to all!!
    I need to copy to minidv tape material in hdv720p but I can not currently monitoring the firewire signal vtr.
    I fail to activate and do not know why allframes?
    My final version is 6.
    Hopefully you can help me thanks!
