Activity Forums Apple Final Cut Pro Legacy print quality- ProRes(HQ) or 8 bit uncompressed
  • print quality- ProRes(HQ) or 8 bit uncompressed
    Posted by Ashish Sah on September 23, 2013 at 3:41 am
    Is there any difference between the quality of apple ProRes(HQ) and 8 bit uncompressed or apple ProRes(HQ) convert from 8bit uncompressed file. we are making digital print for cinemas. which will be best.
    Bill Dewald replied 12 years, 11 months ago 3 Members · 3 Replies
  • Michael Gissing
    September 23, 2013 at 4:15 am
    If you are just making the ProRes HQ from an 8 bit uncompressed then you may as well just send the 8 bit uncompressed. ProRes is a transcode and has compression.
    ProRes HQ is 10 bit depending on the original source so would look better if your original material was 10 bit.
  • Ashish Sah
    September 23, 2013 at 4:35 am
    tnx
    my original footage is Apple ProRes (hq) and if i convent it in 8 bit uncompressed, will the quality of film be improvised.
  • Bill Dewald
    September 23, 2013 at 6:10 pm
    If your original footage is ProRes HQ, that’s as good as it will be (which is still very good).
    Transcoding to uncompressed would be a waste of time and space.
