Activity Forums DaVinci Resolve print on 35mm from Davanci
  • print on 35mm from Davanci
    Posted by Mohamed Sami on November 19, 2011 at 10:58 pm
    hello
    i want To Know….
    i have footage From Alexa – i made color – i made export to DPX files –
    now i want to print it on 35mm!
    -which type of the 35mm roll i use??
    -any setting i should to make before exporting to DPX??
    – I should to use or choose any LUTs before coloring ?????
    i want to know everything
    Robert Houllahan replied 14 years, 10 months ago 3 Members · 2 Replies
  • Michael Phillips
    November 20, 2011 at 2:32 am
  • Robert Houllahan
    November 20, 2011 at 8:44 pm
    Did you grade in Rec-709? or Log?
    You can usually get away with a 709 grade and have the lab translate it into the film print. This is the easy way but is not the best way.
    To do it right you would want a Film Print LUT which was made from a calibrated film recorder shootout and print from the lab. Doing this will “close loop” the whole color management system and take into account the recorder, the internegative stock, the print stock, printing and film processing for the lab you are using.
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
