Activity Forums Maxon Cinema 4D Primitive fillet vs Bevel Deformer Chamfer
  • Primitive fillet vs Bevel Deformer Chamfer
    Posted by Darren Lee on March 12, 2020 at 12:20 pm
    Hi, I’ve been using the Bevel Deformer a lot to Chamfer or Fillet polygons (not sure what the difference is between the two).
    The fillet that comes with a Primitive is perfect, but the Bevel Deformer seems to leave gaps
    If I optimise the edges, it seems to work, Is that the correct way of doing it ?
    Darren Lee replied 6 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Justin Thomson
    March 12, 2020 at 7:19 pm
    Sorry I cannot replicate the issue, the bevel deformer on an editable cylinder work fine for me.
    When you get to the top, don’t forget to send the elevator down for the next guy
  • Darren Lee
    March 13, 2020 at 9:50 am
    That’s strange, I thought I’d try a newer version of C4D (that one was R19) so I opened the same file in R21 and noticed this option appeared:
    And it works fine. Is this a bug in R19?
  • Justin Thomson
    March 13, 2020 at 2:52 pm
    I don’t have that option either.
  • Darren Lee
    March 13, 2020 at 2:55 pm
    ok thanks
  • Brian Jones
    March 13, 2020 at 3:51 pm
    Optimizing is correct, the primitive cylinder is made as three pieces so the bevel deformer only works correctly when it’s all one object not three
  • Brian Jones
    March 13, 2020 at 3:56 pm
    no not a bug in R19, they have just been upgrading things like the cylinder so you can check off Single Object (I think that’s it, I don’t have 21 here) like you could (in 19 etc) with the Boole and others so it will work with the deformer properly without having to be made editable.
  • Darren Lee
    March 13, 2020 at 3:58 pm
    Great, thanks for confirming!
