Activity › Forums › Adobe After Effects › Primatte vs KeyLight
  • Primatte vs KeyLight
    Posted by Peter Stenhouse on April 4, 2005 at 9:51 pm
    Hi there. I have just keyed out a music video using Keylight in AfterEffects. Is this usual practice, as I understand that it is not the preferred, industry standard for getting rid of green screen. Why is that, why should I use Primatte in shake instead. Was just wondering about the pros and cons of either.
    thanks for any advice or suggestions
    Doyle Rockwell replied 21 years, 6 months ago 2 Members · 1 Reply
  • Doyle Rockwell
    April 5, 2005 at 6:02 am
    Hey Peter,
    The only industry standard for keying, that I know of, is whatever gets the job done for the current project. Depending on how stuff is shot, the quality of the lighting, the green/bluescreen, the format (compression. etc), Primatte, Ultimatte, Keylight, the Discreet keyer, DVmatte, even the Adobe Color Difference Keyer, any of these might be the right tool for the job. Primatte and Ultimatte can get similar results on the same type of footage, while Keylight tends to be different. With Keylight, I usually find that it’s either going to work or not, pretty quickly, without much tweaking. When it works, it’s dead-hot-sexy. Ultimatte, given a clean plate, can provide an amazing key. Primatte, for me (mileage definitely varies), makes for easy matte-pulling but only provides average-to-good results.
    Again, as I said, there’s no one uber-keyer. It’s just whatever keyer does that particular shot best with the level of tweaking you’re willing to put into it. Hope this helps!
