Activity Forums Apple Final Cut Pro Legacy primatte RT inside 7
  • primatte RT inside 7
    Posted by Jeremy Doyle on June 26, 2012 at 6:53 pm
    When I’m adjusting the preview I get it the way I want it to look, but when I render, I get a ghost.
    Here is my shot.
    Here are my settings.
    Here it is with my settings applied, but unrendered.
    Here is what I get after rendering.
    I had copied and pasted the primatte filter from another clip that rendered correctly and shot on the same background.
    Any ideas?
    Jeremy Doyle
    https://www.jeremydoyle.com
    Jeremy Doyle replied 14 years, 2 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    June 27, 2012 at 5:20 pm
    Odd… what are the properties of the source material, and what are your sequence settings?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Jeremy Doyle
    June 27, 2012 at 5:49 pm
    Odd to say the least.
    Source is XDCAM sequence is ProRes.
    Not sure why it worked before and now it doesn’t. When I send it to motion and apply the same filters it works. It worked in FCP on a previous episode and I’ll try again of a future episode.
    I went ahead and keyed it with the chroma keyer and the results are fine. The hair isn’t quite as nice as using Primatte, but its workable.
    Jeremy Doyle
