Activity › Forums › Apple Final Cut Pro Legacy › Primatte Keyer for FCP, Motion, or AE
Posted by Roger Lee on August 14, 2009 at 2:22 amI want to get Primatte Keyer from Red Giant Software. Which program would you suggest I get it for? FCP, Motion or AE??
Thanks for any help!!
Erik Lindahl replied 17 years, 1 month ago 6 Members · 6 Replies -
Tom Wolsky
August 14, 2009 at 2:27 amHave you tried the Primatte keyer in Motion? It’s also now in FCP7.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
John Fishback
August 14, 2009 at 2:45 pmKeylight (which has been a keying mainstay in AE for the last few versions) is now available for FCP. I prefer Keylight, but they’re both excellent keyers.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Greg Nosaty
August 14, 2009 at 3:01 pmI agree with John.
Keylight for FCP is great and I believe it does a better job than Primatte in Motion. For good basic keying it works very well without the hassles of exporting your media to another app. Although you have finer control of Keylight in AE if you are working with problematic green or blue screen footage or want to do more complex compositing.
cheers,
Greg NosatyCinemontage Productions Inc
Jason Diebler
August 14, 2009 at 6:21 pmRoger is talking about the Red Giant plugin, not the Primatte keyer that’s built into Motion… they are different. Primatte Keyer Pro is definitely worth investing in if you have the $$.
I’ve used the native filters in FCP/Motion & Keylight in AE, and I prefer (by far) the Red Giant plugin. It slows your render times 2x, but it takes seconds to set up and pull a key… and does incredible work on poor footage.
If you have Lynda.com there are some very useful demos that compare this plug-in against other like keyers. Check this out if you can (you can do a 1 day free trial if it’s worth your research time).
“The deepest blues are black” – Foo Fighters
(this doesn’t help me when I’m chroma keying!) -
Roger Lee
August 14, 2009 at 9:50 pmThanks Jason,
I’ve been hearing a lot of really good things about the Primatte Keyer from Red Giant. Thats why I came on here to ask people who’ve actually used it against other keyers. I’ve been hearing the same things over and over.Again, thanks for the input!
Erik Lindahl
August 17, 2009 at 8:18 amI thought Red Giant software had the “feature” of “buy one, use for all” as in buy one plug-in and use it for all host-apps. I might be wrong in this however…
I’m also looking for other alternatives to the Keylight plugin in After Effects. It often does the trick but not always and Keylight looks at a keying jobb different to Primate if I’m not misstaken (i.e. the outcome of a key can vary).
Primate for Motion vs “the real deal” from Red Giant is hard to compare. The Motion plug-in was built for speed (realtime keying). I would also say depending on what you do, the choice of keyer or application / workflow can also vary a lot. DV Matte from dvGarage has proven to be very impressive before and it’s only 199 dollars.
https://www.dvgarage.com/prod/prod.php?prod=dvmattep3
Erik Lindahl
Freecloud Communication
