Activity Forums Adobe After Effects Prickly circle – howto?
  • Prickly circle – howto?
    Posted by Roger Maus on October 31, 2021 at 5:45 pm
    Hi there,
    I would like to animate a prickly, spikey circle. I attached a picture which shows the aesthetic I am trying to achieve. (grey background)
    I already did some tests with Turbulent Displacement plus Radial Blur, yet it looks “wrong”. And it’s quite demanding, regarding performance. (example with black background attached)
    Any ideas?
    Michael Szalapski replied 4 years, 10 months ago 3 Members · 5 Replies
  • Anders Hattne
    October 31, 2021 at 6:47 pm
    I found I achieved a similar result with a shape layer:
    Make two circles. Top copy I set to 2 points larger than the bottom one.
    The bottom one I added a Wiggle Paths. Size 76, Details 86, Smooth Points, 0 frequency (For example..).
    And below all that Merge Paths in Add mode.
    Lastly a Stroke…
    Was gonna see if you could add several Wiggle Paths to create smaller and larger details, but then After Effects stopped responding.. 🙃
  • Roger Maus
    November 1, 2021 at 9:50 am
    Thanks a ton!
    Just added Simple Choker to smoothen it out.
    See attached clip for final result: it’s the circle on the very right.
    PS: i can’t embed videoclips here, can I?
  • Anders Hattne
    November 2, 2021 at 11:54 am
    So that ended up working for you in the end?
    A completely different method, that Harry Frank did, (I believe) was just a line, displace it with greyscale gradients distoring the line with Displacement Maps and then using Polar Cordinates to make it a circle.
    Probably would be a lot slower though.
    No idea if you can attach videos. Have not been active here for two ! years!
  • Roger Maus
    November 2, 2021 at 3:28 pm
    Hi Anders,
    yes I am happy with the outcome. Polar Coordinates is a powerful tool, but your approach is easier to handle.
  • Michael Szalapski
    November 2, 2021 at 5:39 pm
    That looks like something you could get with the Roughen Edges effect set to spike.
