Activity Forums Adobe After Effects Expressions Previous keyframe triggered movement
  • Previous keyframe triggered movement
    Posted by Fletcher Groeneman on October 16, 2019 at 5:56 pm
    I have a layer I want to position differently if an expression control checkbox is ON vs OFF.
    It is all working except it changes back as it approaches the next checkbox keyframe:
    cb = thisComp.layer(“Controller”).effect(“Alert”)(“Checkbox”);
    t = cb.nearestKey(time).time
    value1 = [33.6667, 161.4107]
    value2 = [33.6667, 141.4107]
    dur = 1
    start = t
    end = t+dur
    if (thisComp.layer(“Controller”).effect(“Alert”)(“Checkbox”) == true) ease(time, start, end, value1, value2)
    else ease(time, start, end, value2, value1)
    How do I write it so that this animation only triggers AFTER the keyframe?
    – Fletcher Groeneman
    Fletcher Groeneman replied 6 years, 10 months ago 1 Member · 1 Reply
  • Fletcher Groeneman
    October 16, 2019 at 7:19 pm
    Better yet, how would I have the animation trigger if a value goes above a certain threshold.
    IE if a number is > than 5 play this animation ease(time, start(as soon as the value went above the threshold), end (start + duration), value1, value2)
    But once it returns to under the threshold of 5 reverse that animation like this: ease(time, start(as soon as the value went back below the threshold), end (start + duration), value2, value1)
