Activity › Forums › Adobe Premiere Pro › previews not updating
Posted by Ron Smorynski on October 18, 2007 at 4:04 pmI am importing jpg sequences in ppro 2.0. All is well but…
when I update the source jpgs, the previews in the timeline do not update. I have to delete files, save & close ppro, the re-open and re-import clips.
Is this a bug? or is there something i’m missing?
thanks
ronWil Renczes replied 18 years, 10 months ago 3 Members · 4 Replies -
Mike Velte
October 18, 2007 at 4:49 pmTechnically speaking, compressed files like jpegs cannot be edited, only replaced with a .psd or …copy.jpeg. When you choose “Edit Original” in Premiere, the still opens in PS, make your changes and choose “save” and default format is PSD. If you choose Jpeg as the format and drop the changed file into the same folder, PS will append “Copy” in the file name.
Tiffs, BMPs and PSD are editable.
Ron Smorynski
October 18, 2007 at 4:53 pmi am not using Photoshop at all.
i am animating, rendering sequence as jpgs. (to save space)
i will do some corrections to animation, rerender same jpgs, thusly updated.
but ppro will not update the clip in timeline, nor the preview render. however source jpgs in bin are the updated jpgs, as viewed in ppro monitor.
thanks
Ron Smorynski
October 18, 2007 at 5:20 pmOOOOHHH I SOLVED IT!!! Phew!!!!!
Okay, so it checks the FIRST image in sequence! If that was not updated, then whole thing is considered old.
So when I rerender fixes, I need to just render whole sequence, not just area where I fixed.
NO PROBLEM!
Thanks anyway…
PHEW!!!!
Wil Renczes
October 20, 2007 at 6:51 pmThat sounds like a painful way to do it. If you prefer to spot correct individual jpgs, one way to force an update to the clip in Premiere is to offline the clip in the project window, then relink back to the first frame.
There’s also an option (I believe in the sequence menu) that will allow you to delete preview files if you want to flush your timeline renders.
