Activity › Forums › Adobe After Effects › Previewing Comp
Previewing Comp
Posted by Elaine Lake on February 7, 2012 at 7:20 pmFor some reason, when I want to preview my comp, it doesn’t let me preview the whole thing… It stops toward the end and starts at the beginning…
How do I preview the entire comp??
Thank you!
Elaine Lake replied 14 years, 7 months ago 4 Members · 4 Replies -
Cassius Marques
February 7, 2012 at 8:05 pmAren’t you just running out of RAM for the preview? You can try to purge everything (EDIT -> PURGE -> ALL) before previewing to get the most of it…but that’s it.
John Cuevas
February 7, 2012 at 8:39 pmBy pressing B and N, you can set the in and out points of your preview, if you are running out of RAM(previews are just frames stored in your RAM).
Remember if you change your work area, you will want to change it back when you go to render your final composition.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Michael Szalapski
February 7, 2012 at 9:37 pmThis link should help:
FAQ: Why does RAM preview only play part of my composition? [link]– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Elaine Lake
February 8, 2012 at 5:00 amThank you! That’s exactly what I needed — to allocate more RAM 🙂
