Activity › Forums › Maxon Cinema 4D › previewing a tiff sequence material
  • previewing a tiff sequence material
    Posted by Sean Cusson on October 18, 2006 at 1:05 pm
    I’m pretty sure I had this working at one point but can’t seem to get it working again. I’ve loaded a .tiff sequence onto a “screen”. I need to see the sequence play back within the scene when I scrub the timeline. I’ve checked the posts here dating back 6 months and I keep searching through the help files within the program with no luck. This should be a very simple thing to do, a checkbox somewhere or a btn I haven’t pressed. Does this feature exist in 9.6?
    Sean Cusson
    Q media design
    sean@qmediadesign.ca
    Sean Cusson replied 19 years, 11 months ago 2 Members · 4 Replies
  • Björn Marl
    October 18, 2006 at 5:16 pm
    Should be no problem since 9.6. Before 9.6 only the background object was capable of showing image sequences in the editor.
    Does it work for you when rendering? If not maybe something went wrong when creating the material.
    Cheers
    Bj
  • Sean Cusson
    October 18, 2006 at 7:08 pm
    So is it automatic or do I need to enable something?
    Sean Cusson
    Q media design
  • Björn Marl
    October 18, 2006 at 8:10 pm
    In the illumination part of the material enable “Animate Preview”
    Cheers
    Bj
  • Sean Cusson
    October 18, 2006 at 8:21 pm
    Dammit that’s what it was. I didn’t upgrade to 9.6
    Sean Cusson
    Q media design
