Activity › Forums › VEGAS Pro › Preview without effects
  • Preview without effects
    Posted by Joschka Lauke on July 21, 2008 at 6:44 pm
    I am wondering if it is possible to turn off the visual effects of an entire project in order to have a smooth preview. Is there a way (in Vegas 7) to disable the effects temporarily without having to click on every single file in the timeline?
    Thank you!
    Garsti
    Marlen Mathers replied 13 years, 1 month ago 4 Members · 4 Replies
  • John Rofrano
    July 21, 2008 at 7:32 pm
    Use the Split Screen view (the button is 4th from the left above the preview window) and enable FX Bypassed with the Select All option. This will allow you to quickly toggle the video FX on and off.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Douglas Spotted eagle
    July 21, 2008 at 7:37 pm
    Click the “Bypass FX” button in the Preview Window. Looks like a half-moon. That’ll shut them all down.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Marlen Mathers
    August 11, 2013 at 4:56 pm
    Hello All –
    Similar issue as the post above, but the “FX Bypassed” toggle is not working for me.
    I can select “Left Half”, and “Right Half” and see the FX applied to the clip. However, when I choose “Select All” no FX are applied and it is defaulting back to “FX Bypassed”.
    Any thought as to why this is happening?
    Thanks for any help…
    Marlen
  • Marlen Mathers
    August 19, 2013 at 7:00 pm
    That did the trick Douglas! Thanks for the tip…It’s funny that you can use a program for years, and then one setting gets changed, and you feel like it’s the first time you used the program as you try and figured out what you did!
    Appreciate the help.
    Marlen
