Activity Forums VEGAS Pro Preview vs Best Render
  • Preview vs Best Render
    Posted by Nathan Halder on October 21, 2011 at 7:23 am
    I shot some street scenes from a car window at 1080/24P. In Vegas 10, I sped up the footage about 2.5 times. When I ram preview and render using the Sony AVC Internet template in using PREVIEW for the project it looks pretty good – not sharp, but pretty good. When I render using BEST (which I always do), it doesn’t look so hot.
    The screen shots are now confusing me. When I watch as I edit in Preview/Auto, I don’t see the ghosting. The Best/Full is on top and the Preview/Auto is on the bottom. In the timeline screen, both ways look different – only when I used the snapshot, do they appear to be the same.
    I am probably going to answer my own question here, but when you speed up 24fps to 2.5 times normal are you asking for trouble?
    John Rofrano replied 14 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • Nathan Halder
    October 21, 2011 at 7:32 am
    I think my question was answered inadvertently by the gentleman two posts down – I turned off the resampling and now it looks great!
  • John Rofrano
    October 21, 2011 at 10:39 am
    [Nathan Halder] “When I render using BEST (which I always do), it doesn’t look so hot.”
    It’s probably important to note that there is no reason to render at BEST unless you are resizing video. The difference between BEST and GOOD is that BEST uses a more complicated resizing algorithm which increases render time by about 2x. This is why GOOD is the default. You can save yourself a lot of render time by using GOOD unless you are resizing.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeff Schroeder
    October 21, 2011 at 12:11 pm
    John,
    If I had 1920 AVCHD and my render was 1280 and in the pan/crop I zoomed in to 1440 would I get better results with Best or would Good be enough. I guess I should try it. What are your thoughts.
    Jeff
    Windows 7 64-bit, ASUS P6X58D, i7 960 3.20GHz, 24.0GB DDR3, 12TB connected storage
    http://www.narrowroadmedia.com
  • John Rofrano
    October 21, 2011 at 3:09 pm
    [Jeff Schroeder] “If I had 1920 AVCHD and my render was 1280 and in the pan/crop I zoomed in to 1440 would I get better results with Best or would Good be enough.”
    Since you are resizing you might try BEST and see if you can tell the difference. That’s the real test. If you can’t see a difference, it doesn’t pay to use BEST because it takes a lot longer to render (unless render time is unimportant to you). You may only see a difference when resizing very large images and not just going from 1920 to 1280.
    ~jr
  • Mac Mcginnis
    October 21, 2011 at 4:22 pm
    I need to ask a really stupid question here. So the end result quality of your video is also determined by what you have your preview screen set at? I guess I really never have asked the question of what the different variations of the preview screen are for.
  • John Rofrano
    October 21, 2011 at 4:53 pm
    [Mac McGinnis] “I need to ask a really stupid question here. So the end result quality of your video is also determined by what you have your preview screen set at? I guess I really never have asked the question of what the different variations of the preview screen are for.”
    That’s actually a GREAT question and the source of some confusion. The answer is NO, the preview setting DOES NOT affect the render at all.
    The preview will, however, show you what the render will look like at a given setting. Most people need to keep the preview low to keep frame rates up, but if you are color correcting or working with plug-ins, you should change the preview to match your final render setting occasionally just to check how things will look. Some plug-ins, especially those that generate effects like fire, smoke, rain, snow, etc. will look very different in PREVIEW mode vs GOOD or BEST. So it’s always important to check what they look like at the render setting quality.
    ~jr
  • Mac Mcginnis
    October 21, 2011 at 4:59 pm
    John,
    When you say render settings, is there an option no matter what template is used to render at a good or best setting? I may have just never noticed it if there was, or like you said, used the default of good.
    Mac
  • John Rofrano
    October 21, 2011 at 10:12 pm
    [Mac McGinnis] “When you say render settings, is there an option no matter what template is used to render at a good or best setting? I may have just never noticed it if there was, or like you said, used the default of good.”
    Yes, in your project properties there is a setting called: Full-resolution rendering quality and it defaults to Good. In the render templates there is a Project tab with an option called Video rendering quality which defaults to: (Use Project Settings). This is how you make any template use good or best regardless of anything else.
    ~jr
