Activity Forums Adobe After Effects Preview to ram slow to start
  • Preview to ram slow to start
    Posted by Tim Stonesifer on October 20, 2009 at 6:02 pm
    Lately, when doing a ram preview, my machine will quickly render the first couple of frames. Then, there is a delay of about 30 seconds, and it resumes rendering at the appropriate speed. This is a new system, but early on it didn’t used to do this. I’m using an i7 with 12 gigs ram. Any thoughts on why the delay?
    Tim Stonesifer replied 16 years, 10 months ago 3 Members · 4 Replies
  • Tim Stonesifer
    October 20, 2009 at 6:47 pm
    Interesting. Two thoughts:
    One, what’s an ideal codec to use? Quicktime? I do often bring in m2v footage. Is there a transcoding program that’s popular?
    Second thought: I checked out a project that has no video in it and did a ram preview. The preview doesn’t stall out for the 30 seconds that it does for other projects, but it does hang for a half second about 8-10 frames in. Obviously, that’s not a big deal, but I thought it might give some more insight into what’s going on.
  • Ryan Mcafee
    Just a shot in the dark but maybe something is competing with AE. Since you said your comp is new maybe there are updates running in the background.
    Ryan McAfee
    Moon Community Access Television
    http://www.MCA-TV.com
  • Todd Kopriva
    October 20, 2009 at 7:08 pm
    One possibility:
    If you’re being overly aggressive with the use of the Render Multiple Frames Simultaneously multiprocessing feature, starving some of the processes of RAM, then After Effects can take a little time to shut down a few of the processes so that it can keep going.
    If you’ve only got 12GB of RAM, you probably shouldn’t be using all of your processor cores in an 8-core system, but instead should leave a few for other applications.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Tim Stonesifer
    October 20, 2009 at 7:33 pm
    That’s gotta be it. The settings only list 4 cores, but I limited AE to 3 cores and tweaked the ram settings. That seems to fix it. Looks like I’ll futz around with that a bit more. Thanks for the ideas, guys!
