Activity Forums Apple Final Cut Pro Legacy preview render time
  • preview render time
    Posted by Lili Lab on April 28, 2006 at 9:26 pm
    Rendering preview:
    Hi, I’m Wondering if people have a savvy trick to reducing render time for preview. I’m using heavy processing filters like magic bullet and g nattress to generate specific looks. A lot of the time I want to just preview it (in motion, not just a still) to see if that is the specific look I want. And if not tweak a little more. A way that I have found to get around this is by reducing the render in the sequence settings tab, to 33 %. Render it out, take a look at it and if I like it re render. I’ve realized that when copying my files to a new sequence that is 100 %, the red render bar doesn’t show up. It takes the file as is. Problematic cause I don’t want the crappy render. So What I do is, instead of making a new sequence, I keep my original sequence that’s set for 33% and change it to 100%. No re render needed, which I find strange. Hence, I go to the render manager, and delete the render files for that particular preview sequence. Double check that my preview sequence (that I now want to do a full render) is at 100%, and re-render. Is this the best way to shave of preview render time? Does anyone have tips for this?
    lili
    Lili Lab replied 20 years, 4 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    April 28, 2006 at 11:50 pm
    Set an IN and an OUT very close together then click “Render In to Out” (Apple-R).
  • Lili Lab
    May 1, 2006 at 3:18 pm
    I have used that, but even then, it’s not a long enough clip. Have you tried the 33%? Is this a right way to correct render time?
    thanks,
    lili
