Activity Forums VEGAS Pro Preview HDMI
  • Preview HDMI
    Posted by Mark Krueger on August 23, 2011 at 10:14 pm
    Does Sony Pro 9 have the ability to preview rendered material through a hdmi connector to display on a Large sony bravia TV?
    My computer has an hdmi connector but I am not sure of its functionality.
    When I went to preferences on preview devices I did not see the option of HDMI. I hooked the TV up to the HDMI from the computer, but did not see anything.
    Any help appreciated.
    Frank Stevn replied 15 years ago 3 Members · 2 Replies
  • John Rofrano
    August 24, 2011 at 4:17 am
    [Mark Krueger] “Does Sony Pro 9 have the ability to preview rendered material through a hdmi connector to display on a Large sony bravia TV? “
    It should. Sony Vegas Pro 9.0 supports output via Windows Secondary Display so if Windows considers the HDMI output a candidate for the secondary display, then it should work.
    Otherwise Vegas Pro also supports output via an AJA Io Express, Xena 2K, LH, LHe, LHi, LS, or LSe SDI, or a Blackmagic Design Decklink HD Extreme, Intensity Pro, or HD Extreme 3D SDI.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Frank Stevn
    August 24, 2011 at 10:46 am
    “ability to preview rendered material”
    You can ‘preview’ what is to be rendered in the time line.
    Once the project is rendered you should use a video player application to play the video in your hdmi connected tv.
