Activity Forums Adobe After Effects Preview flicker problem
  • Preview flicker problem
    Posted by Tim Clark on November 8, 2005 at 3:56 pm
    Hi
    just upgraded to AE6.5 on a G5.
    My example image is a still picture panning ( I’ve tried slow and fast pans)
    When I do a ram preview it flickers on my video output monitor, similar to the fields being the wrong way round. AE does not give preferences for this, only for rendered clips. I’ve gone through al the open GL settings. Every setting I know of I’ve tried (and that’s a few)
    Is it an Adobe problem, (can I write any code in the prefs file?) Mac or Blacklink Video Card problem? (Blacklink is set up ok). The same example previews fine in AE 5.5
    Many thanks
    Tim Clark
    Hernan Retamoso replied 20 years, 10 months ago 2 Members · 3 Replies
  • Hernan Retamoso
    November 9, 2005 at 7:49 am
    yes, i’m having the same problem. (AE 6.5, OSX 10.3.8, G5 dual, Blackmagic SP). Ram Preview inverse the fields order.
    Hern
  • Tim Clark
    November 9, 2005 at 9:29 am
    Have you found a way round it? I’ve put the same question out on 3 different forums.
    Thanks in advance
    Tim
  • Hernan Retamoso
    November 11, 2005 at 9:54 am
    Nothing yet.
    I have the same problem in Combustion 3.
    i will try whit osx 10.4 and the new blackmagic drivers.
    the solution by now is shift-up 1 pixel for preview purpose.
    saludos. hern
