Activity Forums Apple Final Cut Pro Legacy Preview disabled during firewire DV capture
  • Preview disabled during firewire DV capture
    Posted by Matthew Rogers on February 23, 2007 at 4:59 am
    Hello there,
    I just recently purchased a new Elura 100 minidv camera for home use.
    I have control via firewire but cannot get a video or audio signal into the camera.
    The capture window displays the “Preview Disabled” message.
    However I can get a signal to the camera.
    I did however upgrade to FCP 5.1.3 and I did think that was the issue.
    I hooked up the camera to my work laptop that has FCP 5.1.2 on it and works fine.
    So I reinstalled FCP 5.1 figuring that I can upgrade it back to 5.1.2 and all would be well in Mudville.
    Sadly, not the case. I’m having the smae issues in 5.1 and as most of you know for some reason Apple is not offering 5.1.2 any longer.
    So……what do you think my options are.
    Thanks for your time.
    oh ya, I’m using an iMac G5 (with Isight) OSX 10.4.8
    -Matt
    Matthew Rogers
    engine room
    Boston, Ma
    http://www.engineroomedit.com
    Matthew Rogers replied 19 years, 6 months ago 3 Members · 4 Replies
  • Bouncing Account needs new email address
    February 23, 2007 at 5:19 am
    Try looking here:
    https://docs.info.apple.com/article.html?artnum=301852
    This seems to be the answer to many of these kind of problems.
  • Rob Forsythe
    February 23, 2007 at 5:20 am
    This list contains virtually everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
    b. Viewing in the Canvas window on the computer screen.
    c. Being able to record on the external FW DV deck or camcorder.
    d. Being able to capture from a FW device.
    If working this list doesn’t cure the problem… you may have a serious PROBLEM!
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Make sure you have chosen FW output for A/V:
    Final Cut Pro (menu) > Audio/Video Settings… >
    Video Playback: Apple FireWire NTSC (720 x480)
    Audio Playback: FireWire DV
    11. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    12. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    13. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    14. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    15. Important: Quit FCP, then Restart FCP.
    16. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    If you have “lost” your entire FW connection between the Mac and the device, go HERE:
    >Then, start again at my “step 1” above.
  • Matthew Rogers
    February 23, 2007 at 4:10 pm
    Thanks guys for the help.
    I did see that article on trashing the Quicktime receipts. I’ll try it again to see if I missed a step. Once I get home I’ll go through those steps. Thanks for all the input!
    I did bring the camera into work and tried here on FCP 5.1.2 MacPro, and again, works fine.
    Thanks again and I’ll let you know how this works out.
    -Matt
    Matthew Rogers
    engine room
    Boston, Ma
  • Matthew Rogers
    February 24, 2007 at 9:19 pm
    I got it to work, but let me tell you how.
    I trashed the QT receipts and reinstalled QT 7 as the article instructed.
    I followed Rob’s list with no positive results. Thank you by-the-way that list was very helpful and good to know for future problems. Instead of quiting I was going to go through the list again. I re-read this:
    [Rob Forsythe] “1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.”
    I then had second thoughts about my external Lacie Firewire drive not applying to any of these. I disconnected the drive and sure enough I had picture, audio, and control of my camera.
    Thanks for your help, I’m going to see if there is a way I can get both the Lacie and Elura to play well together. In the mean time I’ll just capture to my system drive and move the media over.
    Thanks again,
    -Matt
    Matthew Rogers
    engine room
    Boston, Ma
