Activity › Forums › Apple Final Cut Pro Legacy › preview disabled
preview disabled
Posted by Katie Cooper on May 15, 2007 at 3:55 pmHelp! I am trying to capture HD footage down convert to DV. I keep getting the message “preview disabled” in the log and capture screen.
I have the easy setup in FCP set to “DV-NTSC”
on my camera i have the VCR setting to AUTO
i.link conversion ON
A/V-DV ONstill no luck. Is there something small that I am missing?
Shane Ross replied 19 years, 4 months ago 3 Members · 10 Replies -
Jerry Hofmann
May 15, 2007 at 4:23 pmIt’s probably the settings in the camera. Have it set to DV playback, and not “auto”… And use the “easy setup” for DV NTSC.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Katie Cooper
May 15, 2007 at 4:28 pmalso when I change the camera setting to DV, i get the message “no output image in VCR DV/HDV. change format”
when i switch back to auto this message goes away.
Jerry Hofmann
May 15, 2007 at 4:32 pmWhich Camera? sony something right? Might look in it’s manual… there’s nothing special you need to do in FCP, but there is a combo of settings to do this in the camera…
Jerry
Katie Cooper
May 15, 2007 at 4:37 pmi was also trying with the sony HVR M10U deck but had similar problems
Jerry Hofmann
May 15, 2007 at 4:39 pmMight try trashing preferences in fcp: https://fcprescue.andersholck.com/
If you have a way to capture DV from another DV only device, try that to make sure you’ve no hardware/software problems in FCP.
Jerry
Katie Cooper
May 15, 2007 at 6:09 pmthanks for all your advice!
Now i found out that my footage has been shot in PAL format.
Is this why FCP is acting so weird? Does imovie handle pal ok?
Jerry Hofmann
May 15, 2007 at 10:09 pmYOu need to change the capture preset in FCP to match the recording… if it’s PAL, then set FCP up to capture it as such.
Jerry
Shane Ross
May 15, 2007 at 10:11 pm[Jerry Hofmann] “YOu need to change the capture preset”
HEy, that’s MY signature typo…stop stealing man.
DOuble capital letters is my trademark…
Shane
Littlefrog Post
http://www.lfhd.net
