Activity Forums AJA Video Systems Preview Disabled
  • Preview Disabled
    Posted by Rebecca Gilling on November 1, 2011 at 12:49 am
    I recently upgraded to a Mac Pro Quad Core 2.66GHz. I have the same Kona LHe capture card as I used in my old Power Mac G5. I have the card in the correct slot as advised by AJA, and I uninstalled and reinstalled the correct software (again following instructions on the AJA site). I’m running FCP 7, and when I try to log and capture Digi Beta from a J30 using SDI I get the preview disabled window, even though I can control the deck. Any suggestions?
    Thanks.
    Shane Ross replied 14 years, 10 months ago 2 Members · 3 Replies
  • Shane Ross
    November 1, 2011 at 5:18 pm
    You install the latest drivers? Not just the old ones, but the most current?
    And make sure it is in slot 3 (second from the top). If that doesn’t work, try slot 4.
    Shane
  • Rebecca Gilling
    November 1, 2011 at 8:37 pm
    Thanks for your response Shane.
    Yes, latest drivers installed but will try other slot(s). (AJA recommend slot 2!)
    Cheers,
    Rebecca.
  • Shane Ross
    November 1, 2011 at 8:57 pm
    [Rebecca Gilling] “Yes, latest drivers installed but will try other slot(s). (AJA recommend slot 2!)”
    I guess it depends on the mac that you have. Some have slots that have locked interface speeds, others you can manipulate. APple didn’t remain consistent there. But I swear Slot 3 was always the choice slot. Your machine might have been one of the unconsistent ones. But try Slot 3…no harm in trying.
    Shane
