Activity Forums Adobe After Effects Preview
  • Kalleheikki Kannisto
    March 6, 2019 at 6:39 pm
    AE previews as much of the clip as fits in you computer’s RAM allocated to the program.
    Senior Graphic Designer
  • Walter Soyka
    March 6, 2019 at 6:43 pm
    The length of your preview is dependent on your comp size, bit depth, frame rate, available memory, and preview settings.
    There are a few preview settings you can change to get a longer preview. See here for more:
    https://forums.creativecow.net/thread/2/1135155#1135213
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Gabe De matteis
    March 6, 2019 at 9:07 pm
    Thank you for the insight.
    – I have 24 gb of ram — should one have more for larger files?
    – Along these lines have you experience AE unable to open a large file — I couldn’t open a 3.55 gb file
  • Walter Soyka
    March 6, 2019 at 9:24 pm
    [gabe de matteis] “I have 24 gb of ram — should one have more for larger files?”
    It really has nothing to do with the file size. Ae only stores uncompressed video frames in RAM for preview, no matter what format your footage is on disk.
    But yes, Ae will use as much RAM as you can give it!
    [gabe de matteis] “Along these lines have you experience AE unable to open a large file — I couldn’t open a 3.55 gb file”
    We pretty regularly use Ae with files larger than that. What kind of file is it?
    Walter Soyka
  • Gabe De matteis
    March 6, 2019 at 10:38 pm
    Thank you for the followup….
    The file format is .img and I AE opens them with no problem.
    But it won’t open the 3.55 gb file.
    I’ve allocate 21 of my 24 gb ram to AE — still won’t open it??
    Thanks, for any insight.
  • Walter Soyka
    March 7, 2019 at 10:44 am
    [gabe de matteis] “The file format is .img and I AE opens them with no problem. But it won’t open the 3.55 gb file. “
    Do you get an error message at all?
    Where’s this file coming from? I hear .img and I think “disk image,” not a footage format that Ae can use.
    [gabe de matteis] “I’ve allocate 21 of my 24 gb ram to AE — still won’t open it??”
    I don’t think memory is the problem; I’d advise adjusting that setting back down to leave a little more RAM available to your OS. I would allocate 16 to 18 GB of RAM for Ae on a 24 GB system.
    Walter Soyka
  • Gabe De matteis
    March 7, 2019 at 11:38 am
    Thanks, again for taking the time to respond.
    Revised memory as described but AE still would not open the 3.55 gb file?
    Given I was on deadline my workaround was to break the animation into four parts?
  • Walter Soyka
    March 7, 2019 at 11:42 am
    Ae’s memory usage is unrelated to whether you can open that file or not.
    Do you get any kind of error message when you open that file? Can you open that file in any other application? Are you sure it’s even a valid footage file, and not a DVD image or something that you would need to mount in your OS and extract files from for Ae?
    Walter Soyka
  • Gabe De matteis
    March 7, 2019 at 5:08 pm
    When I try to open it in AE, there’s no message, no anything?
    I’m able to open it Quicktime Pro and PhotoShop….
  • Gabe De matteis
    March 7, 2019 at 5:11 pm
    I should also mention, I can convert the file in QuicktimePro and then open it in AE — but it is “fuzzy”
    I believe I converted it to mp4 and animation — ??
