Activity › Forums › Adobe Encore DVD › Preventing SD clips from stretching in an HD Encore project
  • Preventing SD clips from stretching in an HD Encore project
    Posted by Marc Sandlhauser on October 21, 2011 at 2:37 pm
    Good morning, everyone. I’m putting together a collection of the first five photographic montages I’ve done for my daughter. The first two were done in SD resolution, the final 3 in HD resolution. I’ve got my menus set up and linked correctly. DVD plays great EXCEPT I’d rather not have Encore stretch the two 4:3 clips/timelines to 16:9. Is there any way to prevent Encore from doing this? I’ve also noticed in the properties (I think), the 4:3 or 16:9 choice is grayed out for the first two clips…?
    Thanks in advance…
    Regards,
    Marc
    Jeff Bellune replied 14 years, 11 months ago 2 Members · 3 Replies
  • Jeff Bellune
    October 21, 2011 at 4:29 pm
    You’ll need to do this in Premiere Pro or another NLE.
    Nest your 4:3 montage sequence/clip into an SD 16:9 sequence. Don’t scale to frame size. You’ll end up with black pillar boxing on the sides of the clip. When you export your sequence as 16:9, it will include the black bars. En will see the black areas as part of the 16:9 frame and not try to stretch the 4:3 video.
    If you hate the black bars, then you can creatively fill those areas with other stuff. Check out sports and news channels for ideas.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Marc Sandlhauser
    October 21, 2011 at 4:35 pm
    Jeff, thanks very much. That makes perfect sense. Since her birthday is tomorrow, I was hoping for a setting change. 🙂 This will still be very easy to do. Thanks again!
    Regards,
    Marc
  • Jeff Bellune
    October 21, 2011 at 5:18 pm
    You’re welcome. Happy Birthday to her! 🙂
    -Jeff
