Activity Forums Adobe After Effects Prevent Overlapping
  • Prevent Overlapping
    Posted by Dada Kräuter on August 5, 2016 at 8:44 pm
    Hello, 🙂
    Is there any way to disable overlapping for specific layers? I have two 3D layers which have same Z axis and one half of first comp overlaps second comp. I want to make like that, as the attached picture shows:
    Best regards,
    DADA
    Kalleheikki Kannisto replied 10 years ago 3 Members · 3 Replies
  • Michael Szalapski
    August 5, 2016 at 8:57 pm
    You can force one layer to be in front of the other, but it won’t be exactly in the middle like that.
    The solution is to duplicate your comp so that you have two identical comps. Hide the red layer in one comp and hide the green layer in the other comp. Then pop them both into a main comp and use the Linear Wipe effect to reveal the lower one.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Dada Kräuter
    August 5, 2016 at 11:00 pm
    Okay, got it 🙂 Thanks!
  • Kalleheikki Kannisto
    August 6, 2016 at 6:21 am
    I guess you could cheat it by rotating the layers ever so slightly around the y-axis in opposite directions so that there is a (undetectable) fold between the layers.
    Senior Graphic Designer
