Activity Forums VEGAS Pro Prevent overlap when adding to timeline
  • Prevent overlap when adding to timeline
    Posted by Anmol Mishra on June 5, 2010 at 6:02 am
    When I add a clip to the timeline in between 2 clips, one of the clips end up being overlapped by default. How do I set it up so that – I can add a clip to the timeline, and it will shift all the clips to the right until it fits in ?
    Adam Rose esq. replied 16 years, 3 months ago 2 Members · 1 Reply
  • Adam Rose esq.
    June 5, 2010 at 8:34 am
    turn on Ripple Edit (CTRL + L) before you drop the media on the timeline.
    good idea to turn it off again – leaving it on can be confusing if you’re not used to it
    also, there are 3 kinds of ripple – look it up in the help file
