Activity Forums Adobe After Effects Prevent Outline When Using Iris Wipe Preset
  • Prevent Outline When Using Iris Wipe Preset
    Posted by Kevin Davie on October 3, 2014 at 5:20 pm
    Hi Everyone, although this is my first post, I’ve basically been living in this forum over the past few months. It’s provided me with a very helpful kickstart for an AE project I’m working on (my first AE project). Apologies if this question has been asked before, I did search for a solution, but was unable to find anything that seems to fit my situation…
    I have applied an animation preset from my main composition on 2 separate pre-comps. I’m using the Iris Square Wipe one (Presets>Transitions-Wipes>Iris-Square). The first pre-comp on my timeline transitions with the square collapsing, and the second one transitions with the square expanding. My issue is that I am getting outline artifacts around the object within the second pre-comp. So even though there is a box expanding from center out, you can see the outline of the entire object. Any advice on how to get rid of the outline is appreciated.
    -Kevin
    Roland R. kahlenberg replied 11 years, 11 months ago 2 Members · 1 Reply
