Activity › Forums › Avid Media Composer › prevent C: drive writing in MC5
Posted by Ian Campbell on December 3, 2012 at 8:14 pmHi there.
I work at a university where we are running MC5 on Windows 7 machines with a single user account for all. We have the same problem every year, students filling up the C: drive accidently with media files instead of using the partitions they are provided with. Is there any way to lock avid so it cannot write media files to C: drive?
David Budnetz replied 13 years, 9 months ago 4 Members · 4 Replies -
Neil Patience
December 3, 2012 at 8:42 pmyes there is – in the Media Creation settings you can check filter out launch drive and filter out system drive.
That will stop them from accidentally using the “C” drivebest wishes
Neil
http://www.patience.tv -
Ricky Barrow
December 3, 2012 at 9:17 pmWhat Neil says is correct, however, I have found this must become a site setting and/or you must check the media creation settings every time you boot the app. Also, this does NOT keep “Audio Suite” renders from going to the C Drive unless you go to something like import and click apply to ALL. This is most aggravating. I am the only editor that consistently keeps media off the C Drive but I check Medai Creation Settings religiously, immediately and every time I open the app. – so my advice is train students to do this as a part of the workflow, else they will find their stuff offline when they come to work here because I delete all media on C Drive without question – it has proven to be the best teacher to our contract editors. 🙂
Ricky
Ian Campbell
December 3, 2012 at 9:46 pm[Ricky Barrow] “What Neil says is correct, however, I have found this must become a site setting and/or you must check the media creation settings every time you boot the app. Also, this does NOT keep “Audio Suite” renders from going to the C Drive unless you go to something like import and click apply to ALL.”
I do teach them apply all, and that usually takes care of where captured footage goes, but I have seen avid “forget” media creation settings too many times (especially in the import window or titles).
I wonder if there is a preferences file that holds the settings for drives that could be written on boot by a script? Maybe a third party app out there that will keep things straight?
David Budnetz
December 3, 2012 at 10:32 pm[Ian Campbell] “I wonder if there is a preferences file that holds the settings for drives that could be written on boot by a script? Maybe a third party app out there that will keep things straight?
“You could also create a dummy “Avid MediaFiles” folder by naming a blank document “Avid MediaFiles”, then deleting the extension. I have done this before with fairly positive results. I suppose you could also write a script to delete the mediafiles folder/dummy on shutdown, and writes a new dummy on login.
