Activity › Forums › Adobe After Effects › Presets won’t import
  • Presets won’t import
    Posted by James Geikler on February 16, 2008 at 5:37 pm
    I’m having a problem with loading presets from Bridge. I haven’t used Presets for a couple of months so I not sure when or what I did to get this. I’m getting the message —- After Effects error: Can’t import file “XXX.ffx” unsupported filetype or extension.
    I’m running OSX 10.4 and CS3 with all the latest updates and patches. Anyone have any suggestions?
    Scot Sturtevant replied 13 years, 9 months ago 11 Members · 10 Replies
  • 10 Replies
  • Andrew Zofka
    March 20, 2008 at 5:24 pm
    I’ve got same problem (OSX 10.5 and AE CS3)
  • Jatin Dhruve
    May 10, 2008 at 3:21 am
    I’m running Windows XP SP2 and CS3 with all the latest updates and patches. Anyone have any suggestions?
  • Artesia Adamo
    September 8, 2008 at 7:02 pm
    A friend sent me this info and it worked for me:
    “Add an element in your comp back in AE that can “catch” the effect. For example the alien face effect will not load unless I have a shape layer AND a shape defined that will be taken over by the template.”
    1. Make a new comp
    2. Create a solid
    3. then try importing the pre set or effect, it should come in to AE just fine
  • Jack Nilssen
    April 4, 2009 at 8:23 pm
    In Bridge:
    Preferences > Startup Scripts
    Make sure Adobe After Effects CS4 is checked.
    Click OK.
    Close Bridge and After Effects (don’t forget to SAVE in AE! 🙂
    Restart both.
    Should work fine, if not that’s all I’ve got for ya.
    Jack
  • Oscar Revilla
    May 20, 2010 at 5:33 pm
    I have the same problem using OSX 6.3
  • Ala Mctoom
    August 1, 2010 at 6:53 pm
    I got the same problem but I found out a way to get over it.
    When you select the desired preset in Bridge, don’t double click. Instead, right click and choose: Place in After Effects.
    It worked for me and I hope it does the same with you.
  • Bonnie Koontz
    August 1, 2010 at 10:22 pm
    I was having the same problem and finally figured out that the text has to be highlighted and active rather than just activating the the layer bounding box.
  • Jim Gurney
    August 3, 2010 at 10:37 pm
    I was getting the same message in CS5 until I noticed AE was opening Bridge CS4. Changed the pref in Bridge 4 and 5 and now I can double click to add presets with no error message.
    jgurney
  • Alex Grand
    November 14, 2010 at 10:32 am
    Hey! Buddies, Read ME:
    First of all make sure you programs Adobe AE & Bridge both of them must be opened,for this trick, and another important thing to make sure that you must open your project in AE and make at least one Composition to insert the file in it, them minimize the Adobe AE & Switch to Adobe Bridge Select your “Name.ffx” file them Right Click on it, and then from the menu select the bottom one called “Place in After Effects” it works 100% and Good luck,
  • Scot Sturtevant
    December 16, 2012 at 12:58 am
    You are a “Steely-Eyed” Rocketman!!! Great fix! Not as detailed as I would ave liked as a novice using a 30 day trial of AE… but none the less, it worked! I appreciate the assist.
