Activity Forums Adobe After Effects Presets Problem
  • Presets Problem
    Posted by Patrick Bronte on June 26, 2010 at 7:10 am
    Hi
    I’m following AE Apprentice and have reached the section under “Layer Control”- Adobe Presets. For some reason I can view them in Br and they have been placed into the presets folder in the Ae Presets folder under the Ae applications folder and can be seen there. But I cant access them in Ae in order to apply them to the comp. I’ve enabled them in the Effects & Presets Options menu but still no go!
    What do I need to do to access them in Ae so I can use them?
    Any help would be very much appreciated!
    Todd Kopriva replied 16 years, 2 months ago 3 Members · 3 Replies
  • David Johnson
    June 26, 2010 at 12:31 pm
    You should be able to just go to AE’s “Animation” menu, select “Apply Animation Preset” and navigate to the preset you want within the presets folder … is that not working?
  • Patrick Bronte
    June 27, 2010 at 5:04 am
    It doesn’t seem to be working…when I click on the animation menu its always grayed out [even when Effects and Resets is highlighted?]. Why would it be doing this and what should I be doing to get around it or prevent it?
    Thanks for the reply!
  • Todd Kopriva
    June 27, 2010 at 2:58 pm
    Do you have a layer selected? You can’t choose Apply Animation Preset from the Animation menu if no layer is selected. Animation presets must be applied to a layer. See this page for an overview of animation presets and this page for instructions on applying animation presets.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
