Activity Forums Blackmagic Design Presets not available in sequence or Video playback settings?
  • Presets not available in sequence or Video playback settings?
    Posted by Paul Strilka on July 17, 2007 at 10:10 pm
    I just installed a new BM HD Extreme card. I installed the latest driver (6.3)
    I am running QT 7.2 and FCP 6.0.1
    When I launch FCP it prompts me to select a Sequence Preset.
    The drop down window contains many Blackmagic options- but many others are missing. For example: I only have 3 choices of 1080i 59.94 (10bit, 10bit RGB, or 8bit).
    There are only 2 DVCproHD options.
    And there is no NTSC DV option, etc. Many other codecs missing as well.
    (If I choose CANCEL I do not get a Timeline or Canvas window and they are grayed out the Window drop down menu. If I choose a preset- even one I do not want- I get a complete layout.)
    Once inside FCP- I tried Audio/Video Settings Menu.
    Now- ALL options including 1080i 59.94 ProRes, 1080i 59.94 DVCpro, NTSC DV, etc.
    are sudenly available as Capture presets- BUT they are not listed under Sequence Preset menu. (?)
    If I select Easy Set-up- ALL BM presets are listed.
    but when I try to edit to timeline I get a prompt telling to match settings.
    In addition; Many of these same setting options are missing from the VIEW Video Playback menu as well.
    It’s all very confusing. What is going on here?
    I suppose my question is:
    How do I get All Blackmagic presets to appear as options in all settings- including sequence preset and Video playback?
    Paul Strilka replied 19 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
