Activity Forums Apple Final Cut Pro Legacy Presets for 32kHZ audio
  • Presets for 32kHZ audio
    Posted by Paul Bruneau on July 22, 2005 at 12:23 am
    I normally edit with 48kHZ, 16 bit audio. I received two tapes recorded at 32kHZ, 12 bit audio. I have created a capture preset for 32K. Do I need to also create a sequence preset for 32kHZ? Also When I import audio from a CD in the same project, do I need to convert the 44.1 K audio to 32K rather than 48K as I normally do. This is probably a no-brainer for you more experienced people but it is new to me. Thanks, Paul
    Paul Bruneau replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
