Activity Forums Adobe Photoshop Preset PATTERNS are really only useful if they’re seamless… How best to achieve this..?
  • Preset PATTERNS are really only useful if they’re seamless… How best to achieve this..?
    Posted by David Lincoln brooks on November 9, 2013 at 11:38 pm
    Ive been trying to create my own preset Patterns, the library patterns that can be used to paint with or superimpose in Layer FX upon a layer (Pattern Overlay).
    I’m noticing that such patterns are really at their most useful…when they are seamless.
    Your patterns are necessarily rectangular, since you have to select with the Rectangle Marquee in order to make DEFINE PATTERN active.
    So… what’s the best way to make a preset Pattern candidate that’s absolutely seamless, so it can be tiled or painted with, without the viewer seeing the telltale seam?
    Thanks, David Lincoln Brooks
    Danny Thompson replied 12 years, 10 months ago 2 Members · 1 Reply
  • Danny Thompson
    November 15, 2013 at 3:02 pm
    The offset filter is the key to making repeating patterns by hand.
    Build the center of the pattern, then use the offset filter with values that are 50% of the canvas dimensions. Then proceed to fill out the center again. Repeat with different configurations until you’ve covered up all the visible seams and gaps.
