Activity Forums Adobe After Effects preset effect for having an image slide on screen in multiple panels
  • preset effect for having an image slide on screen in multiple panels
    Posted by Andrew Riss on May 31, 2016 at 2:57 pm
    I know this sounds like a simple effect.
    an image slides onscreen in 2 or 3 panels.
    the way I have been doing it is manually by copying my image layer making a masking and adding the positioning key frames to have each half of the image come on screen at different times,
    the question I have is if there is a script, expression or preset for this because I have several long videos
    Andrew Riss replied 10 years, 3 months ago 2 Members · 5 Replies
  • Oki Pienandoro
    May 31, 2016 at 6:06 pm
    Not sure what you mean by “an image slides onscreen in 2 or 3 panels.”
    Not scripts/preset per-se. But perhaps a workflow like this ?
    https://www.schoolofmotion.com/making-content-for-jumbotrons/
    Sorry for the english, not native speaker.
  • Andrew Riss
    May 31, 2016 at 6:17 pm
    ok, I’ll try to be more clear
    I have a photoshop image
    I want to find an effects that slices it into 3 panels and then each of the 3 slices move onto the screen one at a time.
    it would be great to have controls that I can choose how many slices and the directions of the positioning movement
    any help would be great
  • Oki Pienandoro
    May 31, 2016 at 6:49 pm
    I’m still not sure what you mean by “panel” because any windows in AE is called panel.
    Timeline panel, render queue panel, effects panel, etc
    But in case you mean Split into different layout in the same comp, maybe you can use this :
    https://aescripts.com/splitimage/
    It’s a “Name Your Own Price”, you can actually put zero dollar, so it’s free.
    But if this is helping you, i strongly suggest you buy at the suggested price.
  • Andrew Riss
    May 31, 2016 at 7:01 pm
    right panel wouldn’t be the exact word.
    plane or rectangle would be the right word.
    in any case thanks, I think split image may help me
  • Andrew Riss
    May 31, 2016 at 8:38 pm
    thanks dave,
    maybe I can be a bit more clear.
    I am working on a series of 3 minute videos that use a similar effect throughout them.
    Like I mentioned the image moves on screen in multiple parts.
    Sometimes the footage is a still jpeg, sometimes it is video footage and sometimes it is animated graphics.
    I was hoping to find a preset that slices the video up (which I found in ae scripts) and also has the preset positioning control, (which I saved in my presets)
    kind of looking to have it all in one click if possible.
    especially if I hand the job off.
    thanks again for the help
