Activity › Forums › DaVinci Resolve › Preserving ‘optical flow’
Posted by Jim Bachalo on July 19, 2014 at 6:07 pmUsing FCPX for editing. I need to slow down a number of clips and have applied ‘optical flow’ to the video quality. How do I preserve this when I bring into Resolve?
Eric Johnson replied 12 years, 1 month ago 2 Members · 3 Replies -
Eric Johnson
July 21, 2014 at 5:54 pmEasiest way would be to “bake” the speed change in FCPX and edit it back into the timeline.
eric b johnson
online editor | colorist | workflow
https://vimeo.com/ebjohnson/colorreelSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jim Bachalo
July 22, 2014 at 6:23 pm -
Eric Johnson
July 23, 2014 at 10:34 pmAs long as Resolve interprets the speed changes in the same way then that will work also. I actually read your post to mean you had had bad luck going that route, thus my suggestion.
eric b johnson
