Activity Forums AJA Video Systems preserving flagged frames
  • preserving flagged frames
    Posted by Ewin on July 11, 2005 at 5:36 pm
    Hi, I’m selling some of my 720p 24 footage to someone who wants to use it in their 720p 24 sequence. I have digitized all the requested clips into FCP, lined them up and now only need to lay them back to tape, but I need those flagged frames preserved so that when the client digitizes the tape, the media is still at 23.98fps. In other words, they should be able to pop in my tape and use the DVCPro 720p 24 Easy Setup to digitize the tape and get media at 23.98fps. I know the Kona 2 should be able to lay back to tape with the frames flagged at 23.98 but I haven’t gotten it to work yet. Also, I don’t have two AJ1200 decks so I must go the Kona 2 route. Anyone else tried this or have advice on how to make it work?
    Thank you.
    Marion Laney replied 21 years, 1 month ago 4 Members · 5 Replies
  • Jeremy Garchow
    July 12, 2005 at 4:29 pm
    Why don’t you give them digital files? That way they are 23.98 and close to the original compression. If there’s too much to burn on a dvd-r or four, send them a firewire drive and have them send it back when they are done.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Ewin
    July 12, 2005 at 6:53 pm
    Hi Jeremy,
    Thank you for your reply. I’ll be giving it to a stock footage house that needs the media on tape for their archives to use again and again without storing digitally. Also, I know this should be possible so I want to figure it out.
    I’ll write again if I find the solution.
  • Jeremy Garchow
    July 13, 2005 at 6:03 am
    i would call aja and see if they know the trick to getting the rp-188 out to tape correctly. Otherwise, I’d bill them for the cost of the firewire drive have it sit on a shelf digitally, that way they don’t have to redigitze anyway. It’s the wave of the future anyway. Cowabunga.
    If you speak with aja, post back and let me know what happens.
  • Gary Adcock
    July 13, 2005 at 2:43 pm
    [ewin] ” I know the Kona 2 should be able to lay back to tape with the frames flagged at 23.98 but I haven’t gotten it to work yet. Also, I don’t have two AJ1200 decks so I must go the Kona 2 route. Anyone else tried this or have advice on how to make it work?”
    you need to turn on the User Bits setting on the deck. this is off by default with most of the 1200a decks.
    If you play out a 24p timeline out of the Kona 2 it will correctly flag the content as 24 even though it is playing back at 59.94. But you need to tell the deck to read the timing.
    gary adcock
    Studio37
    HD and Film Consultation
  • Marion Laney
    July 15, 2005 at 2:33 am
    Gary,
    Which menu turns on the User Bits on the 1200a? Is it the one where you tell the 1200a to regen UB and TC?
    Thanks in advance.
    Marion
    Marion Laney
    Director-DP-sometimes Editor
    ideaWercs, inc.
    Atlanta, Ga. USA
    Producing in HD&35mm&SD
    Food Network series “Good Eats” and others.
