Activity › Forums › Adobe After Effects › preserving colors after rendering
Posted by Patryk44 on July 21, 2007 at 5:31 pmHello,
I don’t know if this a matter of codec (I use Sorenson Video 3) or some settings, but when I render my animation the colors look different in QT player than in AE comp window.Patryk44 replied 19 years, 1 month ago 3 Members · 5 Replies -
Bart Straman
July 21, 2007 at 5:40 pmrender in quicktime (Jpeg settings 95% quality) for best result. then look again. if this is the same color as in AE comp. then it’s your sorenso video 3 codec who gives the problem. (play in Quicktime or Powerdvd or something to make sure it’s not your player who gives the trouble)
Bart
Steve Roberts
July 21, 2007 at 9:03 pmI agree. Try different codecs and test. If you have to use a particular codec, you might have to use specific levels or hue/sat settings in AE to bring your colours back to where you want them. Keep in mind that all monitors are different.
Patryk44
July 21, 2007 at 9:49 pmThanks guys. It was a sorenson problem. Another quick questio, which jpg compression should I use:jpg 2000 or photo jpg?
