Activity Forums Apple Final Cut Pro Legacy Preserving Close Captioning on HDCAM master thru FCP
  • Preserving Close Captioning on HDCAM master thru FCP
    Posted by Sterling Noren on February 7, 2007 at 9:39 pm
    Hi All,
    I found a lot good posts regarding close-captioning on the COW but none really answered my questions.
    Ive got a job where Im going to be taking some HDCAM master tapes (with close capturing) and capturing them into Final Cut. After removing some material (with a dissolve in between) Im going to relay them back to HDACM.
    My questions are:
    Will the closecaptioning information come into FCP via the HDSDI output of the deck (passing through a through a Kona2 card on the way)?
    Are there any special settings I have to choose on the deck or in Kona control panels?
    Will I only lose this close caption information on the section of the video where I render the new dissolves (which is okay because there is no talking in those spots anyways)?
    Thanks for any input you might have on this one.
    Sterling
    Sterling Noren
    Owner/Editor/Producer
    WideWorld HD Productions
    Seattle WA
    Mark Maness replied 19 years, 7 months ago 3 Members · 3 Replies
  • Sterling Noren
    February 7, 2007 at 9:45 pm
    I just called AJA tech support and they told me that as long as I capture everything uncompressed the close captioning info will pass through just fine. No special settings required. Wont lose anything.
    thanks
    Sterling
    Sterling Noren
    Seattle WA
  • Shane Ross
    February 7, 2007 at 9:52 pm
    Just don’t color correct or add filters, then render. The renders, as I recall, blow the CC away.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Mark Maness
    February 7, 2007 at 10:04 pm
    Yep…
    I have found out that it works with other codecs as well, just don’t render anything. I’ve done this with XDCAM HD, IMX50, DVCAM, and DVCProHD codecs without a hitch.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
