Activity Forums Adobe After Effects Preserving black while exporting Alpha Channel
  • Preserving black while exporting Alpha Channel
    Posted by Prema Ball on May 4, 2010 at 8:40 pm
    I am creating some lower thirds and I need to export them for use in Avid.
    I have done this before many times, but never using black as one of the colors of the graphic, because I’ve never been able to export the alpha channel and still preserve black as an opaque color within the graphic.
    How can I export my lower third graphic, and maintain the opacity of the black in the graphic and export the alpha channel so everything but my lower third graphic is transparent?
    thanks
    Prema Ball replied 16 years, 4 months ago 2 Members · 3 Replies
  • Prema Ball
    May 5, 2010 at 6:58 am
    Sorry I misspoke on the export/render. Go back and forth between so many programs that sometimes I use the wrong terminology.
    It would be a movie. A quicktime animation codec. Millions of colors + (rgb+alpha) at best (100) quality.
    but the problem I run into, is that if I have black as part of the graphic I’ve made, it comes out translucent, treats the black as part of the alpha. do I have to make the background something toher than black for it to differentiate it from the BG?
    thanks for the response.
  • John Cuevas
    May 5, 2010 at 1:28 pm
    It sounds to me that you used the “BKG color” as part of your graphic, rather than a solid. Test this out by hitting “shift+cntl+b” and change the color to red. If the black part of your graphic that you need changes to red, you don’t have anything there, there’s nothing to create an alpha channel.
    Fixing this is as simple as creating a solid”shift+y” and modifying it so it fits your graphic correctly…ie masking it to fit into the lower third, track matte.
    Also there is a turn background off button under the comp window–little checkboard icon. If you press that, you’ll see exactly what will be transparent or not. Push the green-red-blue circle pulldown and you can also switch to the alpha channel to see what you’re exporting.
    Good luck
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Prema Ball
    May 5, 2010 at 4:36 pm
    I didn’t have to key any part of it, but that is definitely something that I will keep in mind on other projects I’m working on.
    Both John’s and your suggestions have been very helpful.
    Thank you.
