Activity Forums Adobe Photoshop Preserving Alpha Channel for FCP?
  • Preserving Alpha Channel for FCP?
    Posted by Eric Lochstampfor on January 12, 2011 at 8:05 pm
    I’m trying to use a logo, made by our graphic artist in Final Cut, only when I go to it has a white background. When I view it in Photoshop I can see through to the checkered background, so I am assuming the alpha channel is present.
    I’ve tried re-saving it and that causes the background to turn black.
    The PSD is a school logo with only has one layer.
    Any idea what I need to do to be able to use the logo and still get the alpha channel, or where the problem might lay?
    Thanks in advance!
    Christina Outlaw replied 15 years, 6 months ago 3 Members · 3 Replies
  • Christina Rodriguez
    January 13, 2011 at 1:39 am
    Make sure the logo is in RGB mode (in Photoshop)
    Try, in FCP. with the image selected in your timeline, go to Modify>Alpha TYpe and see if it’s set to none/ignore. If so, change that setting.
    If that doesn’t work, let us know.
    C.R.
  • Eric Lochstampfor
    January 13, 2011 at 2:47 pm
    Yup!
    RGB Mode did the trick.
  • Christina Outlaw
    March 8, 2011 at 12:41 am
    For future reference RGB mode is effective because CMYK is not detectable by FCP.
    Hope that helps.
