Activity › Forums › Storage & Archiving › PreRoll Post
PreRoll Post
Posted by Kevin Patrick on August 28, 2014 at 12:16 pmI came across Larry Jordan’s review of PreRoll Post and wondered if anyone here as looked into, or had comments on this product.
Kevin
https://www.larryjordan.biz/product-review-preroll-post-from-imagine-products/
Ajit Nair replied 10 years, 2 months ago 7 Members · 13 Replies -
Kevin Francis
August 28, 2014 at 2:50 pmThere is quite a bit of discussion about PreRollPost in this forum. I posted this user review a little over a year ago:
https://forums.creativecow.net/thread/330/857
Dan Montgomery
August 29, 2014 at 4:57 pmKevin,
We have quite a few users of this software now. It’s matured a lot over the last 3-years. Some of the more recent additions is the (obvious)support for the new mTape LTO drives. PreRollPost installer has all the drivers needed to get up and running in just a click, regardless of your tape manufacturer.
Many users of PreRollPost are supplying video to Discovery Channel and need an easy, certified way to create LTFS tapes that meet their specs.
There’s a free demo you may try, even if you don’t yet have an LTO deck. And of course several tutorial videos available to help you get familiar with it quickly.
BTW, I’m pretty sure mLogic has plans for more reviews of the mTape & PreRollPost together. We and they will both be showing the two products together at IBC for those folks coming to the show.
Dan
Offload with Confidence…
Bob Zelin
August 30, 2014 at 12:46 amHi Kevin –
so exactly what is your question ? Is PreRoll Post a wonderful product ? YES IT IS. Is it worth buying, instead of the free HP StorOpen ? YES IT IS. Is it better than BRU ? That is a stupid question – they are different products. Both are wonderful.Do I love the MLogic MTape – yes I do.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com -
Kevin Patrick
September 1, 2014 at 8:13 pm[Bob Zelin] “Is it better than BRU ? That is a stupid question”
Well then, glad I didn’t ask that question.
I’m about to fall off the fence I’ve been sitting on for some time and finally acquire an LTO based archive system.
I’m glad to hear you like MLogic’s drive, since that’s what I plan on purchasing now that I’ve upgraded to an expansion-card-free Mac Pro Tube.
I was going to go with BRU software, based on what little knowledge I have. I came across PreRoll Post and was just wondering there might be a reason why I’d pick PreRoll over BRU.
Bob Zelin
September 3, 2014 at 9:00 pmboth are great companies. I use both, depending on client demands. PreRoll Post does NOT support tape libraries (only single tapes), so if you need library function, it’s a no brainer – you choose Tolis BRU.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
Tim Jones
September 4, 2014 at 9:20 pmJust to add a bit of compatibility input here – BRU PE and BRU Server both properly support and recognize the mLogic mTape units. In fact, it was our work with mLogic and Areca that enabled the unit to properly handle tape block sizes over 64K.
We are also compatible with the 1 Beyond unit as it uses the ATTO Thunderbolt to SAS bridge.
Tim
Tim Jones
CTO – TOLIS Group, Inc.
https://www.productionbackup.com
BRU … because it’s the RESTORE that matters! -
Bob Cole
September 4, 2014 at 10:42 pm[Bob Zelin] “PreRoll Post does NOT support tape libraries (only single tapes), so if you need library function, it’s a no brainer – you choose Tolis BRU. “
Hi Bob, I know this is a dumb question, but I’m not sure what you mean by this. Are you saying that PreRoll Post won’t span between two tapes? What exactly is the “library function”?
Bob C
Bob Zelin
September 6, 2014 at 4:43 pmHi Tim –
you just said –
In fact, it was our work with mLogic and Areca that enabled the unit to properly handle tape block sizes over 64K.So is Tolis supporting the Areca card now ?
bob Zelin
Bob Zelin
Rescue 1, Inc.
Tim Jones
September 6, 2014 at 8:33 pmNot yet – Areca only fixed things for the embedded TB to SAS adapter used in the mLogic mTape unit. We are still trying to get them to extend the code changes to the entire line. It involves both a driver change and new firmware for the HBAs.
Tim
Tim Jones
Tim Jones
September 6, 2014 at 8:38 pmA library houses multiple tapes – from 8 to 1,000’s. For software to properly use the multiple tape capabilities automatically, it must be written to use the automation capabilities.
With all BRU products, you can use 1 tape to 1,000’s of tapes as a single archive with completely automated spanning of the tapes. With LTFS-based solutions, the user (or the software) must manually split the data to be written to tape into tape-sized chunks (either 1.4TB or 2.3TB) before it’s written. If you try to write more than the adjusted tape capacity to an LTFS volume, you’ll get the same error that you get when you try to write more to a disk than will fit – “No space left on device”.
Tim
Tim Jones
