Activity Forums Adobe Premiere Pro Preroll MultiCam Edits?
  • Preroll MultiCam Edits?
    Posted by Nick Marques on February 18, 2008 at 6:07 pm
    Is there a way to setup Premiere Pro CS3 so that multi-cam edits take place a set number of frames or seconds before you do them? I find that I have to go back and tweak edits a bit because in some cases, by the time you make the edit, you’re already a moment late.
    Ideas?
    Jon Barrie replied 18 years, 6 months ago 2 Members · 1 Reply
  • Jon Barrie
    February 19, 2008 at 8:27 am
    Here’s a work around. You could edit/cut your multi-clip nest file like normal. Then go into the Multi-CLip Nest and then shift the clips down the timeline a little creating an overall push along to the decided edit points. Like making a post-edit pre-roll.
    – Jon 😉
    How many editors does it take to change a light bulb?
